NYZ - PPLZ SYNF : Ltd Tape on Psoma Psi Phi
Ultra-limited Edition of 10 hand dubbed triple cassette box on Psoma Psi Phi. TAPE NOW SOLD OUT
NOW REISSUED ON 4xCDR!!
ALSO ON DIGITAL AT BOOMKAT
Boomkat blerb =>
"The great Dave Burraston (NYZ, Noyzelab, Dave Noyze) renders a sweltering mass of drones made on his self-built version of the Serge/CGS Paperface analog synth to Psoma Psi Phi. While it sounds like heavy machinery, it’s recommended not to listen while using them - you’ll only do yourself a mischief. Best turn off the lights and let this one devour you "
Label's release blerb ==>
David Burraston returns to Psøma Psi Phi with possibly his most expansive release to date - PPLZ SYNF. A gigantic 3.5 hour work consisting of seven pieces created using an ongoing self-build (as Burraston notes) of the Serge/CGS Paperface analog synthesizer, in conjunction with a custom built modular rig. Laid to digital disk space at Burraston's Noyzelab studio in August, PPLZ SYNF is a monolith of drone synthesis that absorbs the listener into some kind of greater collective metaconsciousness. It is both an impressive exercise in longform drone music, and an immersive and hypnotic atmosphere that confounds the mind, transfiguring your surroundings from its unique and singular perspective. A monument, literally and figuratively, in the sound field, etched and erected by a master of the craft.
Given the scope and size of such a release, PPLZ SYNF has been committed to a very special, and very limited, triple-cassette set, housed in a dustproof binder. These are extremely finite and assembled by hand in every possible way, making no two copies exactly alike. The digital version available at Bandcamp consists of cuts from the first of the three tapes, while the full release is spread across two 60-minute tapes and one 90-minute tape.
Released November 14, 2017
W/P by David Burraston. Field recorded in MONO 96kHz/24bit on Zoom F8, August 2017 at Noyzelab (www.noyzelab.com). Created with Serge/CGS Paperface ongoing self build and Mutable Instruments Braids x2 custom dark face build by Finlay Shakespeare. David Burraston and the NYZ logo appear courtesy of Noyzelab. This is Psøma Psi Phi number NYZ-II, and 2nd in Burraston's private NYZ catalog. Cover design by The Analog Botanist.
