NYZ - DSP TRX : Ltd 4xCDr on Psoma Psi Phi
Limited Edition 4xCD-R Set on Psoma Psi Phi.
Also available at Norman Records => "Very talented man David Burraston, aka NYZ, returns to Psøma Psi Phi for DSP TRX, a four hour rager. This is music for fans of: not quite knowing what's going on, being overwhelmed by the enormity of things, and staring at waterfalls. Comes on four CDs, with disk four being a cute little 3"er."
Label blerb =>
Packaged in a clear plastic quad-disk case with a wraparound insert custom printed by David Tagg, and burned into four white in-house duplicated/printed recordable compact discs - the first three on standard 5" CD-R and the fourth on 3" CD-R. Contains the complete 4-hour DSP TRX album.
NOTE: 3" CD-Rs are only playable on tray-based CD players. Do not attempt to play a 3" CD-R on a "front loading" CD player. Buyers assume all responsibility for the care of their stereo systems, and full understanding of this advisory.
Includes unlimited streaming of DSP TRX via the free Bandcamp app, plus high-quality download in MP3, FLAC and more.
shipping out on or around April 10, 2018
edition of 34
David Burraston returns for his third release at P / Psi / P, the mindmelting 4-hour DSP TRX. His second 4xCD-R set in our catalog, after the equally monolithic PPLZ SYNF.
DSP TRX is sometimes manic, turning itself into shapes that seem impossible or unfathomable, and at other times it becomes more stable, barely moving like a deep pool beneath an occasional wind gust. As is Burraston's custom, DSP TRX delivers its most potent and stimulating moments after the sounds themselves have sustained long enough to remove your awareness of time as a reference point. Not quite drone, not only synthesizer music, but wholly a displacing other. The shuddering tone fields stretch out for miles, expanding forever, and then contract again into more observable sections, like a muscle. We're never certain if we're hearing feedback with mathematically-divided holes poked in it, or a radio custom-built by Burraston that tunes into millions of digital bubbles, following traced lines toward a central frequency of his own devising. DSP TRX is both bright and dark, a dramatic rapid tremolo of silence and noise, infinitely revolving, inverting and slowing down - or is it speeding up? Once again, Burraston delivers proof that he is not operating on our plane of reality, or the neighboring ones, but above them all, in an undefined place outside time, space and everything in between.
DSP TRX is available as an edited digital edition (2 tracks) or as a full four-disc/16 track excursion. An unabridged digital release will follow later at Boomkat.
released March 27, 2018
W/P by David Burraston. Recorded March & September 2017 onto 2 tracks / edited December 2017 at Noyzelab. Custom programmed in Spin FV-1 Assembler using the Tiptop Audio Z-DSP Eurorack module and Numberz programmer. All recordings were made direct from the Z-DSP outputs, with minimal post processing other than a slight bit of EQ and stereo placement.
Instruments: 2x Braids Macro Oscillators, ALM Akemie's Castle, Tiptop Z-DSP & Numberz, SpinAsm FV-1 DSP Assembler, MOTU UltraLite-mk3 Hybrid, Apple iMac 2.93GHz Intel Core 2 Duo 4GB RAM / Logic Pro 9.
Thanks to Tiptop Audio for the Z-DSP and Numberz programmer (www.tiptopaudio.com/z-dsp/) Matthew at ALM for the Akemie's Castle (www.busycircuits.com/alm011/) Braids custom dark face build by Finlay Shakespeare (www.twitter.com/FinShakespeare)
