1 VCO
Saw Up, Square,
1 VCA with Decay envelope
1 unique ARP mode
Fri, 12/04/2020 - 08:52
2017
Bass Bott
Link
cyclone analogic webstore
The Woman Tone: Almost 60 Years of Pure ...
Today 11:54 AM
Deals of the Week: Amazing Offers from M...
Today 11:54 AM
Zero-G introduce Elements Silentium
Today 11:54 AM
SSL launch the Bus Comp Classic
Today 11:54 AM
IK Multimedia unveil the ARC Studio+
Today 11:54 AM
RYK Modular reveal the Side FX
Today 11:54 AM
Cableguys release TimeStop
Today 11:54 AM
FAC introduce FAC Gravity
Today 11:54 AM
Today 11:54 AM
