Quantum
Quantum
Quantum
8 Voices
8 Parts
3 stereo digital oscillators
6 LFOs
MIDI IN, OUT, THRU
4 GB Internal Flash memory
Fri, 04/09/2021 - 08:49
Waldorf Quantum
Waldorf Quantum Demo
Hunart©
Roland TD-07DMK2 and TD-07KV2: The Perfe...
Today 03:16 AM
Teenage Engineering EP-35 K.O.-AMP Leak:...
Today 03:16 AM
Arturia update the AstroLab
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
fedDSP release quadCHO
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
