Modular Grid Social Feed -- Grove Audio
A new 8 step voltage sequencer module is available in 5U format. The GMS-775 Sequencer 8 module is an eight step control voltage sequencer in a 1MU panel. The sequencer also generates gate outputs which can be enabled for each step. If a sequence shorter than 8 steps is needed, there is a reset position on each gate toggle to select a shorter sequence.
The sequencer has an internal clock oscillator and can also be clocked externally through the panel clock input connector. This connector also accepts a reset signal so that the sequencer can be stopped, started, and synchronized by an external controller.
A quick look video showing some of the features of the new module can be found here: https://youtu.be/lNbq04I4JjU
The module is available for preorder in the Grove Audio Synthstore: synthstore.groveaudio.com
(Posted on 2018-12-02 20:30:21 by Grove Audio)
https://www.facebook.com/GroveAudio/phot...55/?type=3
Roland TD-07DMK2 and TD-07KV2: The Perfe...
Today 03:16 AM
Teenage Engineering EP-35 K.O.-AMP Leak:...
Today 03:16 AM
Arturia update the AstroLab
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
fedDSP release quadCHO
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
Today 03:16 AM
