Yamaha Reface CS turn off omni mode
Hi! I've been trying to set my reface CS to midi channel 2, but am having problems. I think it's because the machine is in OMNI MODE. This article is the closest I've found to being able to switch the setting off: https://yamahasynth.com/learn/reface/reface-cs-midi-primer-setting-midi-receive-channel
It says:
"Using the reface CS as a single PART with the MOXF or Motif XF Sequencer via 5-pin MIDI cables:
In a situation where you need the reface CS to be respond to just a single MIDI channel, you must turn OMNI MODE to OFF (this action will default the CS to MIDI Receive Channel 1) and then select a different MIDI channel, if you desire. You can turn OMNI MODE OFF by sending a CHANNEL MODE MESSAGE via the MOXF or Motif XF Sequencer: cc124 = OMNI MODE OFF".
I don't understand this - would be great if anybody could lend a helping hand!
Thanks in advance
submitted by /u/BandicootVegetable21
