Modular Grid Social Feed -- Northern Light Modular
Happy new Year folks...
We are getting ready to ramp up production of the Time and Triggers - Model 2TT .
In case you missed it, it is a 5+1 clock pulse generator, driven by the same MCU that powers the 2OC and providing self running or slaved pulse width adjustable 10V triggers and gates.
The pulses can be further combined to form complex layered chains of long and short pulses by using shorting bars.
It also sports a two channel Bernoulli coin toss for further randomisation and an additional swing or ratchet generator.
Or two of both, depending on the firmware you chose to load.
The lower section is also CV controlled and a shorting bar can be used to set the parameters using the random or sequenced voltages from the Time Out jack which runs in sync with the upper section again.
Stay tuned for a proper demonstration video and head over to http://northernlightmodular.com/preorder-2tt/ to get one of the first batch
(Posted on 2018-01-11 12:45:05 by Northern Light Modular)
https://www.facebook.com/NorthernLightMo...45/?type=3
