Pulse 2
Pulse 2
Pulse 2
Up to eight note polyphony
3 Analog Oscillators
Filter -
Two
Two ADSR Envelopes
Mon, 09/09/2019 - 12:15
2013
Waldorf Pulse 2
Waldorf Pulse 2 Manual
Waldorf Pulse 2 - demo
Alba Ecstasy
Córdoba Fusion Orchestra CE Pro: Flamenc...
Today 12:23 PM
Bjooks Beat Gems to begin shipping
Today 12:23 PM
Sonarworks Autumn Sale
Today 12:23 PM
Celemony Tonalic gains additional Paul K...
Today 12:23 PM
XILS Lab introduce MemoryTone
Today 12:23 PM
Warm Audio unveil the Jude preamps
Today 12:23 PM
Sauceware Audio release Scorch 2
Today 12:23 PM
DPA to launch the 6388 Core+
Today 12:23 PM
Guitar Days at Thomann: More Than 500 Co...
Today 11:10 AM
