S3
S3
S3
12 voices
12 parts
8-Track Sequencer
Patterns -
Patterns: (Example: 128 preset patterns, 128 user patterns)
Songs -
30 user songs
2 independent digital stereo multieffectors
Wed, 01/01/2020 - 09:58
Korg first announced the S3 in 1989, but it didn't reach the shops until 1991. Unlike other drum machines of the time, Korg actually designed it with eight-track sequencing on-board as well as digital effects processing. Other standout features for its time include SMPTE read/write capability, along with MIDI Time Code transmission, which gave it a lot of versatility.
It was fairly expensive for a drum machine, but definitely had a lot more to offer than the competition too. Since the S3 can function as an eight-track MIDI sequencer, it can record its own drum and percussion parts in addition to parts from other external MIDI instruments. It can even be set to only play S3 sounds, only MIDI'd sounds or a combination of the two.
Another highlight of the S3 is its 16-bit digital effects processing capabilities. It has two built-in digital effects processors along with 28 programmable effects. Also, instead of playing a single sound at a time from each pad, the S3 actually supports layering. This once again enhances the versatility of the S3.
In terms of layout, the S3 features a very uncluttered design, with everything on the front panel arranged economically. The S3 has a 2x24-character backlit LCD with four buttons below it, a data entry wheel and master volume slider on the top half of the front panel. Below these are the Mode buttons, a pinpoint LED run-time indicator, seven control buttons, as well as the drum pads. All eight of the drum pads are velocity-sensitive. Meanwhile, the rear panel houses the power input, on/off switch, MIDI input and outputs, footswitch inputs, headphone outputs, and SMPTE timecode jacks. You'll also find two ROM PCM sample card slots and a RAM data card slot on the rear panel. The two PCM ROM sample card slots can hold up to 40 card samples to compliment the 75 internal samples of the S3. The RAM card can stop up to two banks of 8 Timbres, to fill out the 80 preset Timbres. The RAM card can also be used to store up to 20 Kits if you want more than the 10 factory-preset Kits that are stored in ROM.
The S3 is not the easiest device to program, but users who stuck with it appreciated its versatility. Korg went against the flow when they designed the S3, which makes it one of their most unique instruments.
1991
Korg S3
KORG S3 DRUM PATTERN 1.wmv
Compurythm303
KORG S3 Rhythm Workstation
Synth Universe
http://www.vintagesynth.com/korg/S3
Olydian Musical Instruments Intros VC-01...
Today 02:47 AM
Stylophone Mini Turns The Classic Pocket...
Today 02:47 AM
UVI Releases Falcon 2027 : Plus three ne...
Yesterday 11:26 PM
Virtual Italian String Orchetra : IK Mul...
Yesterday 11:26 PM
New Granular Synthesis Plugin : Delta So...
Yesterday 11:26 PM
Yesterday 01:46 PM
Yesterday 01:46 PM
TC Electronic 2290: The U2 Delay
Yesterday 12:04 PM
Yesterday 12:04 PM
