CGS Infinite Melody Machine
Infinite Melody
for music synthesizers.
The previous version can be found here.
The name of this module is a play on its function. Put simply, it generates a series of semi-random or themed stepped control voltages, or if you prefer, white and pink control voltages. The pink function is probably better known as 1/f, and thus the name of “1l/lfinite melody”.
Assuming a 1 v/oct VCO is being driven by the module, in the 1/f mode, the size of a pitch step is inversely related to the frequency at which it will occur. In other words, the smallest steps are most common, steps twice their size occur half as often, and so on.
As well as the 1/f mode, it has a pure random mode, where no weighting is put on the selection of notes. A large step is as likely as a small one.
As well as having these two modes of operation, there are 4 CV outputs available. With the exception of the fourth, each successive output is a shifted version of the previous. In random mode, this is very much the same effect as produced by an Analog Shift Register (ASR), but in 1/f mode, it takes on a whole new feel, as each of the six shift registers involved shifts at a different rate, according to the 1/f weighting. As such, the second and third outputs are related to the first, but not identical to it. The fourth output is subject to the same shifting weighting according to the mode of operation, but instead of driving a D/A converter, it drives a bank of knobs, allowing harmonic relationships to be set up.
And if that wasn’t enough, the randomness used by this module is obtained externally, from a regular white noise generator, or other varying voltage source, allowing more structured themes to be created. The random values are loaded in series at a rate determined by an external fast clock. This can simply be a spare output of a VCO (even one in use playing melodies etc.) or it can be deliberately controlled, or slowed right down to gain even more effects. The sensitivity of the random input can also be controlled via CV, again giving more possibilities.
See Diatonic Converter for an alternate output for this module.
A little on how it works:
The schematic of the Infinite Melody.
First, a very simple theory lesson – 1/f implies a weighted ratio between a level and its corresponding rate. A change in level of 1 will occur at the clock rate. A change in level of 2 will occur at half the clock rate, a change in level of 4 will occur at a quarter of the clock rate, etc., thus giving rise to the 1/f ratio. This means the larger the step in output level, the less frequently it will occur. On the other hand, random implies exactly that – there is no determination of how great a step will occur – any step size is as likely as any other.
As is shown in the schematic, the Infinite Melody consists of several distinct sections.
The first section is the clock and random or 1/f selector. The clock and reset signals are processed by the LM358. When the 1f/Ra input is LOW (below about 2V), the reset line of the 4024 will be held LOW, allowing it to count, and clock signal connected to the second input of each EXOR gate via the 10k resistor will be blocked by the forward biased diode. The output of the counter is then fed via the EXOR gates (inverted in the process) to the clock inputs of each of the 4015 shift registers. Each successive shift register receives it’s clock at half the rate of the one above it.
When the 1f/Ra input is HIGH (above about 2V), the reset line of the 4024 will be held HIGH, forcing all of the outputs of the 4024 to LOW. The clock signal connected to the second input of each EXOR gate via the 10k resistor will pass as the associated diode is now reverse-biased, and no longer blocking the signal. The clock signal is now fed via the EXOR gates (inverted in the process) to the clock inputs of each of the 4015 shift registers. All shift registers are now being clocked at the same rate.
The second section of the schematic is the random number processor. Each shift register in the chain requires a random level to be present at its data input when it receives its clock signal. Traditionally this would be achieved by having a series of six independent random number generators. Instead it was decided to clock random data in serially at a rate significantly higher than needed. This section is essentially identical to the Gated Comparator, so I suggest you investigate that article for more information on how it works.
The block diagram of the Infinite Melody.
Construction
The component overlay for the VER2.0 PCB. Click here for an enlarged, printable version. Print at 300dpi.
Before you start assembly, check the board for etching faults. Look for any shorts between tracks, or open circuits due to over etching. Take this opportunity to sand the edges of the board if needed, removing any splinters or rough edges.
When you are happy with the printed circuit board, construction can proceed as normal, starting with the resistors first, followed by the IC sockets if used, then moving onto the taller components.
Take particular care with the orientation of the polarized components, such as electrolytics, diodes, transistors and ICs.
When inserting the ICs in their sockets, take care not to accidentally bend any of the pins under the chip. Also, make sure the notch on the chip is aligned with the notch marked on the PCB overlay.
The master level pot for the mix-out is optional. It can be omitted if the resistor marked 27k* is installed. If using the pot, do not install the 27k resistor.
Euro rack users can cut the PCB along the row of holes, and double the board back on itself. You will need to install links between the two parts of the PCB. Pads are provided for this. There are two mounting holes that match on each board, allowing them to be secured to each other.
Pad identification
0V 0V/GND connection for 3.5 or 6.5mm jacks and CCW end all mix bit pots.
CLK Clock input to advance the melody. “ADVANCE” on Best of GCS panels.
-V -VE access point if required.
MSW Common contact of MODE switch.
MB0 Mix bit. Goes to CW end of corresponding mixer pot. (1 on Best of CGS Panel)
MB1 Mix bit. Goes to CW end of corresponding mixer pot. (2 on Best of CGS Panel)
MB2 Mix bit. Goes to CW end of corresponding mixer pot. (3 on Best of CGS Panel)
MB3 Mix bit. Goes to CW end of corresponding mixer pot. (4 on Best of CGS Panel)
MB4 Mix bit. Goes to CW end of corresponding mixer pot. (5 on Best of CGS Panel)
MB5 Mix bit. Goes to CW end of corresponding mixer pot. (6 on Best of CGS Panel)
BD4 To common connection of optional bit 4 disable switch.
BD5 To common connection of optional bit 5 disable switch.
LA Sense LED Anode
LC Sense LED Cathode
P1 Gain pot connects between the two pads marked P1. Wiper is wired to CW end of pot. POT HAS NO 0V CONNECTION.
O1 Output for sequence 1
P2 Gain pot connects between the two pads marked P2. Wiper is wired to CW end of pot. POT HAS NO 0V CONNECTION.
O2 Output for sequence 1
P3 Gain pot connects between the two pads marked P3. Wiper is wired to CW end of pot. POT HAS NO 0V CONNECTION.
O3 Output for sequence 1
PM Optional master gain pot connects between the two pads marked PM. Wiper is wired to CW end of pot. POT HAS NO 0V CONNECTION.
OM Output for mixed sequence
MIX IN Each goes to the wiper on oneof the mix bit pots. There are two extra inputs that can be wired to external input jacks, or an offset pot.
SV Sense control voltage input. If using a panel that has a level pot for this input, wire the jack to the CW end of a 100k linear pot. The CCW end goes to 0V and the wiper goes to the SV pad on the PCB.
ST Initial Sense voltage setting pot CW end
SC Initial Sense voltage setting pot wiper
SB Initial Sense voltage setting pot CCW end
RI Input for random analog or digital pulse train
+V +VE access point. To one side of mode switch.
RC Fast clock for random loading, for example from any VCO in your system, even if it is being used for other purposes at the time. If you are hardwiring to CGS31 digital noise board, this can go to the output of the CGS31’s onboard VCO.
An example of hard wiring the Infinite Melody board. If building the unit into a Best of CGS panel, the Channel Gain pots are replaced with fixed resistors soldered directly to the PCB. 100k will give unity gain. Smaller value resistors, resulting in smaller steps may be of more use to some people. On this example the 27k marked “27k*” is installed, and the master gain pot (GM pads) is not used.
VER 2.0
Part Quantity
Capacitors
47p 8
1n 1
100n (0.1) 13
10uF 25V 2
Resistors
RL – select to suit LED 1
330R 4
1k 2
4k7 5
10k 7
15k 1
22k 2
27k 1
33k 1
47k 1
100k 1% 48
200k 1% 24
4M7 4
Semi’s
1N4148 3
TL072 6
4015 4
4024 1
4030 or 4070 2
BC547 1
Misc.
Ferrite Bead (or 10R resistor) 3
0.156 4 pin connector 1
cgs32 PCB 1
Notes:
  • This module will work on +/-12 volts.
  • Make sure you use a standard 4000 series CMOS, not 74XXX4000 series, e.g. CD4015, MC14015, HEF4015.
    Markings such as HC4015, HCT4015 imply 74HC4015 and 74HCT4015 and are unsuitable.
  • If you don’t care about power-rail noise, just use a link instead of the ferrite beads.
  • PCB info: 6″ x 3″ with 3mm mounting holes 0.15″ in from the edges.
  • Please email me if you find any errors.
Parts list
This is a guide only. Parts needed will vary with individual constructor’s needs.
If anyone is interested in buying these boards, please check the PCBs for Sale page to see if I have any in stock.
Can’t find the parts? See the parts FAQ to see if I’ve already answered the question. Also see the CGS Synth discussion group.
Posted in Uncategorized | Comments Off on CGS Infinite Melody Machine
SynthWizards KaosMidiFire
Eye started experimenting with generating random MIDI data ages ago
Recently some Wiggler posted topic thread searching for True Random MIDI
Therefore challenged myself as a fast refresher project
virtual static x2
VCO/LFO
BPM Sync LFO 8b to /32 range
my original white noise method kept crashing sampler causing hard reboot error
plus added external gate option
so it can be manually played or sequenced for Kaotic midi noise Blasts
no clue if that’s what you were saying
works for me
Eye will record some demo tracks when have extra time
made multiple versions
one that is safe for hardware samplers… doesn’t cause machine reboots
another that prime for using Midi CV/gate…. high speed midi bursts
The extreme Sampler crashing version is getting stuffed with features
such as 32b to 1/64th note host clock sync LFO
White & Pink noise Wave options
plus anything else that was forcing hard reboot on my Ensoniq sampler
because it works awesome with VSTi & MIDI to CV/Gate
Time for recording more Kaos Midi Fire Experiments!
Posted in Uncategorized | Comments Off on SynthWizards KaosMidiFire
Have A Nice Day!
Posted in Uncategorized | Comments Off on Have A Nice Day!
SynthPunk Input Processor
Posted in Uncategorized | Comments Off on SynthPunk Input Processor
SynthPunk Joystick/Voltage Reference/Distribution Amplifier
er… does what it says in the post title..
Posted in Uncategorized | Comments Off on SynthPunk Joystick/Voltage Reference/Distribution Amplifier
SynthPunk 3 by 3 Mixer Matrix
theres 3 of these in one module. the attenuverting input channels (theres three on each mixer board, and 3 boards, so 9 inputs in total) are wired so that all 3 inputs on mixer 2 and mixer 3 are normalled to mixer 1s inputs. so you can set up some pretty crazy RGB mixes and feedback loops with only a small number of inputs. each mixer also has a DC bias and an output gain control, (voltage gain of 1 to 10 times) and also a paralleled output for feedback loops. this isnt buffered, and probably should be…
UPDATE 20110310:
I found some more files – this appears to be the PCB image i made mine from. the quote on the PCB is a Coil lyric. most of my PCBs have a Coil reference on them.. I generally design freehand PCB images in MS Paint whilst i think up the schematic in my head, then build them, then draw a schematic. ill have to reverse engineer my own synth in order to draw up a parts placement pic which might take a while, sorry…
Posted in Uncategorized | Comments Off on SynthPunk 3 by 3 Mixer Matrix
SynthPunk Sync Processor
you should probably build at least 2 of these. they accept positive or negative going sync pulses in any polarity or voltage between -12 and 12 volts and can extract a clean positive or negative trigger for the VCO’s. this means you can use pretty much any Sync Pulse generator or VCO circuit with this device. and as its basically just a comparator you can use it for other purposes within a patch too.
a jolly useful circuit in my experience, and one im pretty pleased i came up with. another nice feature is you can set the threshold so that its output sync pulses can lag behind the input slightly, which seems to give some control over colour. which is nice.
Posted in Uncategorized | Comments Off on SynthPunk Sync Processor
SynthPunk Video VCA and mixer by Tom Gamble of EFM
Heres a damn fine module, that i had no part in designing. its an EFM module, designed by Tom Gamble back in 1999. i was lucky enough to buy a load of his PCBs back then and have enjoyed building them, making music with them and endlessly tweaking them ever since.
low res schematic. download the proper PDF below:
anyways, back to the plot.. this is an excellent audio modular synth circuit, its the VCA5B design from toms 1900 series modules. it works very well and in exactly the same way as with audio at video frequencies too. i have no technical specs to back this up, but it works for me….. its also where i borrowed the design for the attenuverting inputs in my synth- its the same circuit but every 47k resistor or pot has been exchanged with 100k because i happened to get a good surplus deal on hundreds of 100k pots. guess what part most of my designs will be featuring for the forseeable future…
the PDF is here
the various corrections from the old EFM forum are here
and both of the above are linked to from this excellent site, which i have mentioned before. go there and read. then go build stuff.
Posted in Uncategorized | Comments Off on SynthPunk Video VCA and mixer by Tom Gamble of EFM
SynthPunk the good Video VCO
heres the other VCO circuit ive been using recently. its an EFM design once again, but this time there are some changes from the original; ive got rid of the square wave and changed a cap and a resistor.
heres the schem in roughly edited form:
The original copyright holder of this image is Tom Gamble. i edited it a bit and changed some stuff, but its still essentially his work.
once again, all rights and respect to Tom Gamble (and Bob Moog!!) for this design, all i did was change a couple of values and get rid of the squarewave output. i tried it and it worked. hooray!
download the full gen on the audio version here
Posted in Uncategorized | Comments Off on SynthPunk the good Video VCO
SynthPunk video comparator circuits
heres some schematics for the comparators. type 1 is used for sync processing. feed any h or v sync signal in, patch the outputs to the sync input jacks on some vcos, and twiddle the knobs and flick the switch till you get sync lock. easy. no pcb layout for these as i built them on stripboard.
type 2 grounds the negative side of the threshold pot, and takes the +V side through a switching jack, so you can insert an external signal to be used as the threshold voltage. useful for making a pwm squarewave or various other patches. both circuits have hysteresis controls to clean up the output a bit.
both of the above circuits are run from plus and minus 12 volts. the 3k9 pull up resistor means the output swings rail to rail, so it can trigger either of the 2 vco designs (one syncs on a -12 volt spike, the other on a +12) with ease.
Posted in Uncategorized | Comments Off on SynthPunk video comparator circuits
